Forums › The Car › 206 Problems › Clock display (MDF?) backlight ALWAYS on |
Posted: Fri Jun 09, 2017 8:39 am |
Hello, my first post! I seem to have this little problem in my 206 - www.206info.co.uk/Foru...light.html
The backlight never switches off and is always on with the full blast - had to disconnect it so it doesn't wreck my battery! It's been like that for some time now, so I tried to research a bit and found the topic above - I've tried to cycle the ignition on and off for over 30 minutes - with no results
Is it because I gave up too early, or maybe, could it be the comm2000 unit? I had it fixed ~4 times in the 2 years I have this car and its starting to switch on headlights on its own again...
Posted: Wed Jun 14, 2017 11:06 am |
Well the answer is the topic you had the link for,he replaced it with a second hand one,and all is working well,so you can try this method.
