Latest: eniniex
Overall: 17113
Online Now [24]:
Visitors: 22
Members: 1
Today: 7945
Total: 93810902
Forums › The Car › 206 Problems › Peugeot 206 caliper bolt help
Danweider
PostPosted: Fri Jun 16, 2017 9:20 am Up
Hi, I had planned to do some work on the Peugeot 206. Taking the brake calipers off, removing the frame, the pads, and discs and giving it all a good clean. Now the first 2 bolts, to remove the caliper, was easy no problems there. Now the 2 bolts to remove the caliper frame, brought me to a halt. I think its a Torx hole, but I am just wondering whether any one else has come across this issue and know the size of the Torx, piece needed?
Any help would be greatly appreciated!
Dan
mtempsch
PostPosted: Fri Jun 16, 2017 11:36 am Up
Dan
A quick search (see up left) for 'torx caliper size' spat out two posts that say it's T55
Silvermetallic 2004 206 RC
PostPosted: Fri Jun 16, 2017 1:57 pm Up
Is it a later 206? Earlier ones had a 19mm bolt which is much better. I know the 207 used torx bolts.
cube
PostPosted: Mon Jun 19, 2017 8:21 pm Up
You'll need a T55 torx bit matey
206 1.1 independence 54 plate, 3 door
(West Yorkshire)
Danweider
PostPosted: Tue Jun 20, 2017 12:19 pm Up
Thank you for your help guys, I did in fact go and get a T55 bit but I am yet to do the work as the heat is making the floor too hot at the moment. Its a 2005 Peugeot 206, so whether or not they changed the bolts for security reasons or something im not sure Smile
gazza82
PostPosted: Wed Jun 21, 2017 9:42 am Up
Danweider wrote:
... so whether or not they changed the bolts for security reasons or something im not sure Smile
It's because they are French and they can ... Laughing
PostPosted: Fri Jun 23, 2017 5:30 pm Up
I can guarantee you won't be undoing these. Unless you bought a decent solid torx bit and they aren't seized on there.
cube
PostPosted: Fri Jun 23, 2017 6:53 pm Up
Danweider, did you get my PM mate ??
(West Yorkshire)
