Latest: DanDan17
Overall: 17128
Online Now [54]:
Visitors: 53
Today: 4053
Total: 100524016
Forums › The Car › 206 Problems › another airbag light query
xrblue
PostPosted: Tue Jul 25, 2017 8:39 am Up
I replaced the clutch cable and in doing so i had to remove the steering column.
Now the airbag light is on permanently.
Does it need to be reset or do i need to do some fault finding?
cheers
2004 1.4i 206
PostPosted: Tue Jul 25, 2017 8:53 am Up
Fix the fault & the light will go out.
Double check the wiring you unplugged especially the connector plugs on back of the airbag.
Did you centre the steering before dismantling?
If you didn't then the rotary cables can be damaged when you steer lock to lock.
FWIW there is no need to remove the steering column to replace the clutch cable.
xrblue
PostPosted: Tue Jul 25, 2017 9:14 am Up
yep centred the steering. marked it up. its back perfect.
how did u get your hand in to hook/unhook the cable to the pedal?
2004 1.4i 206
xrblue
PostPosted: Tue Jul 25, 2017 11:34 am Up
one of the connectors on the airbag wasn't even connected.
I dont know how I managed that Rolling Eyes
cheers again
2004 1.4i 206
