Central locking packed up several months ago, now indicators on one side only, others work temporailly but very faint then nothing (no obvious bad earths etc), removing battery does not require radio code input - all BSI?
There are possible signs of water on outside of BS! - but non in it.
Power steering lower oil line seals leak, stopped with suitable oil/sealant
Windscreen cracked (passanger side corner).
Its a neat little van than runs well and has been looked after, has done 94,000 miles. Generally can sort most issues/maintenance but unknowns in terms of costs to diagnose / fix stuff I can't.
So should I scrap it or is it worth getting an ebay BSI etc and persisting?
