Latest: S2cgm
Overall: 17178
Online Now [320]:
Visitors: 319
Today: 46079
Total: 136902016
Forums › The Car › Solved 206 Problems › 206 2.0HDI Yr2000 Remote Central locking fault & Fix
CrashBurnFly
PostPosted: Tue Oct 31, 2017 6:17 pm Up
The remote keyfob when pressed would flash and in the car was gentle clunk from under the steering wheel - but none of the doors would lock. I tried the various listed approaches for resetting the BSI, but issue remained. It sounded if the remote signal was being received in the car and a relay was being activated but not passing power to lock up. A search of forums gave confusing views on where the relays were and if they had fuses.
So to cut a long story short the fuse that controls the power for locking/unlocking is the one marked in the picture. I changed this and all worked perfectly.
In RH/UK car the fuse panel is under the steering wheel.
