Latest: ArtistKS
Overall: 17145
Online Now [171]:
Visitors: 170
Today: 4705
Total: 115904928
Forums › The Car › 206 Problems › Rear Heated Window
Rear Heated Window
Jamerz
PostPosted: Thu Nov 09, 2017 6:14 pm Up
My Rear-view window hilariously clears the top 4 lines and nothing below, i have tried disconnecting and reconnecting it but it doesn't seem to want to work, It was working perfectly last year?
Do you guys gave any ideas as to what it could be?
1.1 206 LX, Tivoli Blue
mtempsch
PostPosted: Thu Nov 09, 2017 8:54 pm Up
Given that the +/- wire connections are (IIRC)on the bottom and all heater lines connect to thicker conductors running top/bottom on the sides, [dis/re]connecting will do nothing as the upper lines are getting power...
I'd look carefully for breaks in the thin lines where the window isn't cleared - break-> no current through the line -> no heat...
If there are breaks, they make conductive paint, like nail polish, that can be used to bridge the gaps.
Could have been a piece if cargo that rubbed against the inside of the glass, cutting the lines...
Silvermetallic 2004 206 RC
PostPosted: Fri Nov 10, 2017 9:40 am Up
Could always replace the rear window OR the complete tailgate.
Jamerz
PostPosted: Fri Nov 10, 2017 1:57 pm Up
You know what thats probably spot on totally forgot about some big chairs I moved. Do you think i could bodge it with some tape and copper wire Laughing ?
mtempsch
PostPosted: Fri Nov 10, 2017 3:48 pm Up
[quote="Jamerz"]
If you're decent at soldering you might be able to carefully scrape the ends either side of a break down to metal and then solder a strand from a multi -strand flexible wire across the gap. Don't think tape be able to press it down enough for good contact.
cosmicdance
PostPosted: Fri Nov 10, 2017 9:31 pm Up
You can buy an electrical circuit paint repair kit from Halfords etc which lets you bridge any gaps in the rear demister strips.
Andy
Andy
miweb74
PostPosted: Tue Dec 24, 2019 3:50 pm Up
Hi,my rear demister has stopped heating. There is voltage at the connectors and continuity through the element. Any ideas?
Bog standard 1.4 Auto owner
