Latest: evert
Overall: 17112
Online Now [22]:
Visitors: 21
Today: 13819
Total: 93721919
Forums › The Car › 206 Problems › PUFF OF WHITE SMOKE THEN LIMP HOME MODE
tonyholbury
PostPosted: Thu Jan 25, 2018 12:14 pm Up
Fault code flagged on coil pack replaced fault returned, removed airbox to check crank sensor
LOWER AIRBOX FILLED WITH WATER AND AIRFILTER SATURATED
drilled two 3mm holes in bottom of system, drained a pint of water and replaced air filter.
FAULT GONE
