Latest: Worthy967
Overall: 17143
Online Now [194]:
Visitors: 193
Today: 38842
Total: 115813741
Forums › The Car › 206 Problems › PUFF OF WHITE SMOKE THEN LIMP HOME MODE
tonyholbury
PostPosted: Thu Jan 25, 2018 12:14 pm Up
Fault code flagged on coil pack replaced fault returned, removed airbox to check crank sensor
LOWER AIRBOX FILLED WITH WATER AND AIRFILTER SATURATED
drilled two 3mm holes in bottom of system, drained a pint of water and replaced air filter.
FAULT GONE
