Posted: Wed Jan 31, 2018 9:17 pm |
Hi all,
Have bought a 206 1.4 2008 on Sunday, was in a bit of a hurry as I had work the next day and need a run around just to get me by for a couple of weeks.
Went to view it the guy told me sometimes the car loses power and stalls it’s the coil pack but he hasn’t got round to doing it. He started the car up all seemed fine took it for a test drive was all fine again, drove home and it was fine until the next day it started doing as he said and quite frequently. So I changed the coil pack and if anything it’s made it worse than before it cut out in 2nd gear which it didn’t do before I done.
Sometimes I start the car and in idle then reeves hover from 1000rpm to 900.
I’ll upload a video to YouTube in a minute so you can see what’s happening when it’s cutting out
Here’s the video youtu.be/VPbp5G-1IrE
Thanks for any help
Posted: Wed Jan 31, 2018 9:44 pm |
Most likely the electronic fly by wire throttle body - common problem.
Find someone with Peugeot Planet / Diagbox to scan the car & see what faults are stored.
Most likely find faults stored even with the diagnostic light off.
Hasn't got NGK spark plugs fitted in it?
If it has swop them for Bosch.
Posted: Wed Jan 31, 2018 10:07 pm |
Okay thanks for that will sort it out tomorrow and see how I get on.
Thanks again for your reply.
