Posted: Mon Feb 19, 2018 8:59 pm |
Recently changed ecu / bsi on a 206 gti 138 after buying the car with a bad remap, the car works fine the only issue is my speedometer won’t work but my rev counter does, my car reads speed from gear box but I believe the ecu is from a newer model which reads from wheel speed sensor, is there a fix for this using pp2000
Posted: Tue Feb 20, 2018 10:32 am |
Did it use to work before the BSI change?
Have you been moving the cluster around, disconnecting it etc?
It might just be that the plastic spindle that the stepper motor sits on has snapped, pretty common issue IIRC
Posted: Tue Feb 20, 2018 4:13 pm |
It worked before the change however the new ecu/bsi is from 2004 model which reads speed from abs I believe and 2002 reads from gear box which is my issue just trying to find out if this can be switched by using pp2000
