Latest: jtq4u
Overall: 17141
Online Now [122]:
Visitors: 121
Today: 18647
Total: 113987902
Forums › The Car › 206 Problems › Gear selection difficulty
ChrisOfBristol
PostPosted: Sun Mar 11, 2018 8:49 pm Up
I have read the other threads on similar topics.
My friend's 16V 1600cc 206cc has a gear selection problem. It sometimes works, but usually when I try to select 1st, 2nd or 4th, it appears to go in, but there is no drive. Only 3rd, 5th and reverse are OK.
The upper of the two short gear linkages is a lttle sloppy but not much. I have tried a cable tie on it to see if that fixes it. Not as a permanent solution ☺ but as a test. It makes it worse.
There are two levers on the gearbox, the upper one is worked by the long rod. Apart from rotating, the shaft this is on also slides up and down, is this right?
I would think that the most likely problem is the sloppy linkage, but I'm not sure and would like to be before buying and fitting parts. Could it be a mechanism inside the gearbox?
2005 206cc petrol 1595cc 16 valve
Sim
PostPosted: Tue Mar 13, 2018 11:14 pm Up
So the car is pretty much undriveable? Any specifics of how you eventually get into e.g. the 1st gear? Would double clutching help, and would then the gearstick feel going in "that little bit more"?
The CC I've got over here has a gear switch feel like through jelly, but for now I blame it being stood undriven for many months, might need a cleanup and re-grease
Daily Red GTi 180, year 2004 (VorTechS' sEXy Beast (being) remasteRed)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
