Latest: SA01
Overall: 17138
Online Now [3826]:
Visitors: 3825
Today: 97767
Total: 111412117
Forums › The Car › 206 Problems › Juddering when started and Catalytic Converter Warning Sign
LPD82
PostPosted: Sun Mar 18, 2018 4:44 pm Up
Good afternoon,
Hoping someone can help or point me in the right direction. I have a 206 gti 55 plate, serviced and MOT at start of the year. Started it up at lunch time today, was judderring and shaking, felt like it was going to stall, then Catalytic Converter Warning sigh came up on dash along with yellow engine warning light.
Power seemed to go from the engine and it eventually cut out. Has been sat outside in this freezing weather, but was driven the other day on a 50 mile return journey with no issues.
Any ideas or recommendations what might this be?
Thanks all
mikebrock
PostPosted: Sun Mar 18, 2018 5:40 pm Up
Could be lambda sensors on the exhaust? I would hook up a Diagnostic Fault Scanner to see what error codes it throws out?
spitfire6
PostPosted: Sat Mar 24, 2018 9:49 pm Up
Hi,
More likely spark related. Loose connection to coil pack or coil pack/plug failing.
Cheers,
Iain.
206 cc 2L 16V
GT6 2.5
