Online Now [1002]:
Visitors: 1001
Today: 303076
Total: 150596213
Forums › The Car › 206 Problems › No Heater / Blower - Loose wiring on Ignition Switch?
daddydigdoug
PostPosted: Tue Mar 27, 2018 7:17 pm Up
Hello,
Peugeot 206 LX 2002 Plate
I have gone the last month without my air blower / heating system (tough times but always been safe and cleared windows etc.) but I have just started the car and the blower / heating system kicked in.
I did some tweaking and discovered somehow it's my ignition that's will or will not make it work.
If I start my car normally now it may or may not kick in but If it doesn't twith a little wiggle of my ignition key it kicks in (not everytime though) Shocked
Is the Air Blower / Heater system linked directly to my ignition somewhere?
Can I check the wiring / fix problem easily?
I have electrical tested every part of the system including fuses, resistor and blower individually and all fine which also strengthens the belief it's a wiring / loose connection somewhere.
Any help or info on this matter would greatly appreciated and thank you in advance Very Happy
