Latest: Worthy967
Overall: 17143
Online Now [472]:
Visitors: 471
Today: 60398
Total: 115545460
Forums › The Car › 206 Talk › Changing KPH instrument panel to MPH
Zash
PostPosted: Sat Jun 30, 2018 9:45 pm Up
I have the old style non miltiplexed clocks panel with 2 connectios on a 2001 206 cc 2.0.
The car seems to be imported from Ireland and has KPH speedo.
I notice that the UK version of the speedo hosts needle positions which are identical - only the fascia card with printed numbers seem to be different.
1. Can I simply remove the entire kph dashboard and replace with a mph version?
2. I appreciate that the kph mileage/odometer will be adjusted to whatever number is the larger with regards to the car's ECU and the new dashboard itself. This isn't a problem. My question is - will the odometer reading on the kph version in kilometres be automatically adjusted into miles on the new mph dashboard, if it even works at all?
A bad situation would be where the same reading as kilometres travelled is displayed as miles on the new dashboard!
Thanks for any advice...
-- Zash
PostPosted: Mon Jul 02, 2018 8:09 am Up
On a NON plexed 206 like this - the total distance travelled is only stored in the clock set so it will display whatever is stored in the clocks that are fitted.
PostPosted: Tue Jul 03, 2018 7:15 pm Up
A long time ago, i managed to disassemble my clocks and take the piece out which had the speed written on. Im sure you could do the same and swap?
