Online Now [1112]:
Visitors: 1111
Today: 302365
Total: 150595556
Forums › The Car › 206 Problems › ["SOLVED"] 1.6 16v elongated airbox design issue
Sim
PostPosted: Wed Oct 17, 2018 7:47 pm Up
Once noticed the way the airbox sits on an NFU (TU5JP4) engine (the version with an elongated air filter), that's rubbing against the coolant hose clip to the point it broken through the plastic. I don't think it affects the intake air temperature (negligible), but still.. Rolling Eyes
The simple "fix" is to twist the hose so that the clip points away from the plastic.
Check your engine bay if matches description, as incidentally a 2nd hand replacement part I received also had the same marks:
(now.. no comments on the indented shapes please Razz )
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
