![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › GTI 138 - Oil in Spark plug well |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Tue Apr 02, 2019 8:50 am |
Hi All,
Just been attempting to find some sources on fixing oil leaks in the spark plug wells in my GTI 138. How does one do it? Are there O-rings, or is it replacing the metal shaft which is required?
| | ![](images/spacer.gif) |
Posted: Thu Apr 04, 2019 7:47 am |
I can't remember what the 206 coil pack looked like now ... I think I only removed it once to swap (I change plugs at the same time!) .. but our Alfa had rubber sleeves over the metal shrouds.
If you are getting oil in the plug wells then the cam/rocker cover gasket probably needs replacing.
Posted: Thu Apr 04, 2019 4:01 pm |
More than likely coming from the rocker covers.
Posted: Sat Apr 06, 2019 2:20 am |
Mitch555 wrote: |
Hi All,
Just been attempting to find some sources on fixing oil leaks in the spark plug wells in my GTI 138. How does one do it? Are there O-rings, or is it replacing the metal shaft which is required? |
We had the same problem with our 180 and as above it was the rocker cover gasket off with the cover and you could see the areas it was leaking from with ease new casket fitted never did it again. ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
| Being driven insane by a 1.1 Sport, it only has an Itty Bitty engine. Son has said bye bye to the Sport he now has a Turbo! 2.4 SXHDI 70 Citroen C3 | |
Posted: Sun Apr 07, 2019 5:05 am |
Thanks guys, will attempt the rocker cover gaskets first and see how ut goes!
| ![](themes/base/images/forums/otr.gif) |
