Hoping someone can help.
So I noticed I had an oil leak at front of car, I got my neighbour to have a look who is a mechanic and after inspecting the engine he says it looks like I need new camshaft seals and also to replace the rocker cover gasket aswell at same time.
However as he hasn't replaced the seals on a GTI before he is unsure if the 206 GTI 180 has 2 camshaft seals or 4? (2 each side) and are they all the same type/size.
I have seen these for my mine and wondered if I need 2 or 4?... www.eurocarparts.com/e...01d&000426
Also he said the top of the cam cover uses gasket sealant but was unsure if this is the same at the bottom.
Can anyone help or advice? I just need to know how many seals I need to order.
I tried finding a breakdown diagram but can't find one anyway.
gazza82
Posted: Wed Apr 17, 2019 9:12 pm
The closest you will get is ServiceBox ... PSA parts system. You can create your own login and get to the parts diagrams for free
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
