Latest: Flyin180
Overall: 17116
Online Now [23]:
Visitors: 22
Today: 1996
Total: 95005091
Forums › The Car › 206 Problems › GTI 138 - Oil in Spark plug well
Mitch555
PostPosted: Tue Apr 02, 2019 8:50 am Up
Hi All,
Just been attempting to find some sources on fixing oil leaks in the spark plug wells in my GTI 138. How does one do it? Are there O-rings, or is it replacing the metal shaft which is required?
gazza82
PostPosted: Thu Apr 04, 2019 7:47 am Up
I can't remember what the 206 coil pack looked like now ... I think I only removed it once to swap (I change plugs at the same time!) .. but our Alfa had rubber sleeves over the metal shrouds.
If you are getting oil in the plug wells then the cam/rocker cover gasket probably needs replacing.
PostPosted: Thu Apr 04, 2019 4:01 pm Up
More than likely coming from the rocker covers.
formula1john
PostPosted: Sat Apr 06, 2019 2:20 am Up
Mitch555 wrote:
Hi All,
We had the same problem with our 180 and as above it was the rocker cover gasket off with the cover and you could see the areas it was leaking from with ease new casket fitted never did it again. Very Happy
Being driven insane by a 1.1 Sport, it only has an Itty Bitty engine. Son has said bye bye to the Sport he now has a Turbo! 2.4 SXHDI 70 Citroen C3
Mitch555
PostPosted: Sun Apr 07, 2019 5:05 am Up
Thanks guys, will attempt the rocker cover gaskets first and see how ut goes!
