Online Now [669]:
Visitors: 668
Today: 135330
Total: 145441016
Forums › The Car › 206 Problems › 206 GTI 180 camshaft seal leak
blackpoolwolf
PostPosted: Wed Apr 17, 2019 8:54 pm Up
Hi everyone
Hoping someone can help.
So I noticed I had an oil leak at front of car, I got my neighbour to have a look who is a mechanic and after inspecting the engine he says it looks like I need new camshaft seals and also to replace the rocker cover gasket aswell at same time.
However as he hasn't replaced the seals on a GTI before he is unsure if the 206 GTI 180 has 2 camshaft seals or 4? (2 each side) and are they all the same type/size.
I have seen these for my mine and wondered if I need 2 or 4?...
www.eurocarparts.com/e...01d&000426
Also he said the top of the cam cover uses gasket sealant but was unsure if this is the same at the bottom.
Can anyone help or advice? I just need to know how many seals I need to order.
I tried finding a breakdown diagram but can't find one anyway.
gazza82
PostPosted: Wed Apr 17, 2019 9:12 pm Up
The closest you will get is ServiceBox ... PSA parts system. You can create your own login and get to the parts diagrams for free
