Latest: sparrowdclxvi
Overall: 17139
Online Now [166]:
Visitors: 165
Today: 11379
Total: 113459786
Forums › The Car › 206 Problems › 206sw central locking failure
SuicideBoi666
PostPosted: Wed Sep 18, 2019 5:47 pm Up
So my central locking not working properly,when i want to lock the car with the remote key it just fails like some door is open or something,locking it from the passenger side works (key fob) (EU),when i start driving i have that autolock fuction enabled it also fails and on the screen it says left front door open (EU),when i manually lock it from the inside using that knob on the drivers side everything locks expect the passanger door.So do i have to change the whole mechanism on both sides or have to check for broken wires?
PostPosted: Sat Sep 21, 2019 8:48 am Up
There are microswitches built in to the door latches that control these systems.
Its very rare to get a wiring fault between the door & A pillar on a 206 ( but still check the wiring )
I would suspect the door latch requires replacement.
Be WARNED that the normal central locking & DEADlocking door latches are NOT interchangeable so make sure you get the correct replacement door latch!
