Latest: evert
Overall: 17112
Online Now [29]:
Visitors: 27
Members: 1
Today: 6010
Total: 93728189
Forums › The Car › 206 Problems › Rev counter
Rev counter
lee06121968
PostPosted: Tue May 19, 2020 12:12 pm Up
Hi
My rev counter sits below 0 when off and when started tick over is still under 0
Can anyone help please?
PostPosted: Tue May 19, 2020 3:28 pm Up
If this is an early 206 then there is a known issue with the pointer needles coming loose from the metal spindles.
A carefull application of a drop of superglue once the needle is in the correct position will fix it.
Leave the clear plastic front cover removed overnight so the superglue has time to dry / not react with the clear plastic.
The instrument clock drive units are another known issue but check the pointer needle first.
