Latest: DanDan17
Overall: 17128
Online Now [47]:
Visitors: 46
Today: 10813
Total: 100485636
Forums › The Car › 206 Problems › gti 180 - BSI reset not working
Junglingo
PostPosted: Mon Aug 24, 2020 5:46 pm Up
I seem to have a weird electrical issue. My starter motor was dead so replaced it. Engine turns over now but wont fire. I tried a BSI reset but every time I turn the sidelights on through the window it does not 'bong' instead something weird happens like the rear wiper going or some servos/motors can be heard behind the dash or the doors click, alarm primes. any ideas what the hell is going on?
GTi 180 - Scorpion Exhaust
Sim
PostPosted: Tue Aug 25, 2020 1:44 pm Up
Hi, Needs a scan with planet, suspecting BSI-ECU comms/immobiliser.
Had such weirdness on 1.4 HDi, sometimes also front wipers activate.
To check your immo status: do you hear bleep with the key in ignition when opening driver's door?
Do wipers work in ignition position (probably not, as been hampered by eco mode by now)?
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
Junglingo
PostPosted: Wed Aug 26, 2020 7:46 pm Up
Hi. Thanks. Yes I get the bleep bleep bleep when key in ignition and door open. But yeah nothing works because of eco mode. Because the car has been parked facing down a steep incline it looks like rain water has leaked over the engine bay seal onto the ecu connectors.
Sim
PostPosted: Mon Sep 07, 2020 9:00 pm Up
Check with Peugeot Planet for which fault is causing the non-start. I'd give them a clear too, fingers crossed your ECU has been resilient enough against water ingress!
EV
GTC VXR (sold)
Junglingo
PostPosted: Tue Sep 08, 2020 5:23 pm Up
Thanks. I don’t have peugeot planet, I just have an ELM327 which I’ve scanned with but found no fault codes.
