Online Now [765]:
Visitors: 764
Today: 13498
Total: 127835849
Forums › The Car › 206 Problems › Fan not kicking in when A/C is on
dawik1314
PostPosted: Thu Sep 17, 2020 3:47 pm Up
Hello everyone!
Today I've chaneged relay connectors beacuse they were melted. But when I turned A/C on the fan did not kick in on low speed. Low and high speed does work. Resistor next to radiator is ok. What else can I check?
PostPosted: Fri Sep 18, 2020 10:13 am Up
If low speed fan is working but the A/C isn't - get the refrigerant pressure checked as the pressure safety switch will not allow the A/C system clutch to engage if the system pressure is to low or to high.
dawik1314
PostPosted: Fri Sep 18, 2020 1:29 pm Up
Low speed works when I manually press the relay. It won't kick in when A/C is on or to cool down the engine. No error codes for now in PP2000 Sad
gazza82
PostPosted: Fri Sep 18, 2020 3:09 pm Up
Sounds like you still have a dodgy connection or dodgy relay.
PostPosted: Fri Sep 18, 2020 3:45 pm Up
Planet can run both the cooling fan speeds in the actuator test.
dawik1314
PostPosted: Fri Sep 18, 2020 3:50 pm Up
I have a small update: low speed is not working (even in PP2000)
I also have an error code P0480 for high fan speed
PostPosted: Sat Sep 19, 2020 6:48 am Up
I found it easier to replace the complete cooling fan loom on a 206 then try & repair the original rotten loom.
dawik1314
PostPosted: Sat Sep 19, 2020 7:12 am Up
And how far does this wire loom go? Straight to BSM? Is it easy to remove?
dawik1314
PostPosted: Sat Sep 19, 2020 7:26 am Up
I have 2004 MUX model
