Posted: Thu Sep 17, 2020 3:47 pm |
Hello everyone!
Today I've chaneged relay connectors beacuse they were melted. But when I turned A/C on the fan did not kick in on low speed. Low and high speed does work. Resistor next to radiator is ok. What else can I check?
| | ![](images/spacer.gif) |
Posted: Fri Sep 18, 2020 10:13 am |
If low speed fan is working but the A/C isn't - get the refrigerant pressure checked as the pressure safety switch will not allow the A/C system clutch to engage if the system pressure is to low or to high.
Posted: Fri Sep 18, 2020 1:29 pm |
Low speed works when I manually press the relay. It won't kick in when A/C is on or to cool down the engine. No error codes for now in PP2000 ![Sad Sad](images/smiles/icon_sad.gif)
Posted: Fri Sep 18, 2020 3:09 pm |
Sounds like you still have a dodgy connection or dodgy relay.
Posted: Fri Sep 18, 2020 3:45 pm |
Planet can run both the cooling fan speeds in the actuator test.
Posted: Fri Sep 18, 2020 3:50 pm |
I have a small update: low speed is not working (even in PP2000)
I also have an error code P0480 for high fan speed
Posted: Sat Sep 19, 2020 6:48 am |
I found it easier to replace the complete cooling fan loom on a 206 then try & repair the original rotten loom.
Posted: Sat Sep 19, 2020 7:12 am |
MrBSI wrote: |
I found it easier to replace the complete cooling fan loom on a 206 then try & repair the original rotten loom. |
And how far does this wire loom go? Straight to BSM? Is it easy to remove?
Posted: Sat Sep 19, 2020 7:26 am |
I have 2004 MUX model
