Latest: morgan20
Overall: 17135
Online Now [250]:
Visitors: 249
Today: 144325
Total: 110696002
Forums › The Car › 206 Problems › ABS Sensors, Drum to disk conversion, pre/multiplex issue
Toseland
PostPosted: Sun Sep 27, 2020 8:32 pm Up
The synopsis is i have a 55plate 2.0hdi sport, drum rear axle is borked (more stance than a honda convention) and have replaced it with a disk rear axle in excellent condition
I am under the impression that the car is multiplexed (it's a facelift).
the new disk axle has this type of connector,
I have already (possibly stupidly) replaced the connectors on the car with the suitable female one for the ABS sensors in the axle, but the ABS light is currently on and i am assuming it's a sensor issue
Can anyone point me toward the correct ABS sensor for this axle, without bracing, for the car. Or should any ABS Sensor work and it's just a case of resetting the warning now (assuming both of the sensors are good).
i dont want to go and buy a pair of sensors to find out that they're the incorrect ones.
Help would be greatly appreciated.
