Latest: eniniex
Overall: 17113
Online Now [17]:
Visitors: 15
Members: 1
Today: 1282
Total: 93828254
Forums › The Car › 206 Problems › 206 GTI 180 front seat causing airbag issue & light on
AdDeTa
PostPosted: Wed Sep 23, 2020 7:15 pm Up
Evening all.
Just started playing with the gti I bought a few days ago. A few issues but nothing major
• rear brake pipes popped in the clip area
• rad fan is missing
• stereo cables have all been chopped so need reconnecting
• couple of error codes but cleared them to see if they came back and only the rad fan codes are showing
But my biggest issue at the moment is the front seats were sold/part exchanged and all I have is some standard seats out of another 206 without any plugs / wires.
As you can probably guess the airbag light is on so I need a quick fix until I can afford to replace with genuine seats or proper buckets. A proper fix would probably be best as buckets will definitely be going in, when is a different question though.
Any help would be great
‘04 1.4 8v - Moonstone - No issues
‘54 GTi 180 - Onyx black - Off the road for MOT work
For a person who despises french cars I feel a slight collection coming on
PostPosted: Sat Sep 26, 2020 6:46 pm Up
The airbag ECU is different between a 206 that has just front airbags fitted & a 206 that has side & / or curtain airbags fitted.
The GTI 180 had front, side & curtain airbags fitted.
If you has access to Peugeot Planet you could try & go in to the airbag ECU configuration & tell it the side airbags are ABSENT.
That MAY work but I cannot say for certain as the airbag ECU will see the satellite sensors & curtain airbags connected.
Other then that - replace the airbag ECU for one from a 206 that just has front airbags fitted - You may have to unplug the curtain airbags & satellite sensors from the system.
Shame you never asked this question 2 weeks ago, I've just recycled a pair of 206 airbag ECU's - one of each type.
AdDeTa
PostPosted: Tue Sep 29, 2020 7:38 pm Up
I thought they would be and this option did seem like a sensible idea but when resistors will cost me less than a few quid to sort out as a temporary fix it seems as though I’ll go for resistors, any chance of knowing what resistance they’d need to be ? Someone mentioned 3.3ohm to me but did want to confirm first before sending a bag out over my head
Henk50
PostPosted: Mon Oct 05, 2020 6:05 pm Up
For the airbag on the steering wheel I have used this week 2.2ohm, that works. I think this will also the right value for the other airbags.
Peugeot 206 XT 1.4 2002
AdDeTa
PostPosted: Thu Oct 08, 2020 12:11 pm Up
Thanks bud, I’ve ordered some resistors. Worst case scenario the airbag light stays on because of an incorrect reading. Was hoping someone could stick a multimeter on their seats but had no luck on here or Facebook
ekjdm14
PostPosted: Thu Oct 08, 2020 1:21 pm Up
I think a lot of folk would be (rightly) wary of sticking a meter into any pyrotechnic device, because there's always the chance that the voltage the meter puts out in order to measure resistance could trigger the thing.
Not 100% sure how likely this is (seems unlikely to me, I do want to test on a scrapper though!) but I doubt many people would want to take a chance on their good seats lol.
FWIW you can get a decent selection of resistors from ebay dead cheap, I'd get a load of different low values and just keep changing things round mixing/matching and checking with planet until it says it's happy.
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
AdDeTa
PostPosted: Thu Oct 08, 2020 1:54 pm Up
Yes I can see where your coming from, I was very wary of airbag systems until I had a play myself
AdDeTa
Yes I can see where your coming from, I was very wary of airbag systems until I had a play myself Laughing from what I can gather a multimeter doesn’t send a strong enough amount of power through the system as I’ve tested some steering wheel bags this way but obviously they’re all different.
Then again there must always be power flowing through because issues in resistance is what throws the lights up is it not ? Correct me if I’m wrong (not trying to sound obnoxious but can’t think of any other ways to word it Shocked )
I’ve ordered some resistors and will have a play on my next free day and should have planet sorted out pretty soon with thanks to a member on here.
From what I can gather most french airbags measure between 2.0 and 2.4 so I’ll jump in with a 2.0 ohm and work up to 2.4
