Latest: eniniex
Overall: 17113
Online Now [50]:
Visitors: 49
Today: 9686
Total: 94003017
Forums › The Car › 206 Problems › 140 and 180 wiring loom
Tk1405
PostPosted: Wed Dec 30, 2020 9:14 am Up
Hi all
Would i be able to use a 180 wiring loom on a 140 engine? I know there might be a couple of spare sensor connectors.
Thank you for your help
J206PUG
PostPosted: Wed Jan 20, 2021 8:22 am Up
Depends on the age of the car, they did change the plexing after the first 2001 role out. Not sure when though, so could be quit different. e
What did I miss ???
PostPosted: Wed Jan 20, 2021 6:58 pm Up
The 180 inlet is all different though so connectors might not reach to the correct place. Cam sensor is in a different place too.
