Forums › The Car › 206 Problems › Rear rises on handbrake?? |
Posted: Sun Jan 03, 2021 6:51 am |
I've noticed that, when I park on an incline (nose pointing uphill), and apply the handbrake, the rear of the car rises quite dramatically as I ease off the foot brake
Is this a rear axle bush problem?
Or is this car just haunted or something?
Posted: Sun Jan 03, 2021 3:16 pm |
Normal ... torsion bar rear suspension.
Posted: Sun Jan 03, 2021 5:08 pm |
It's down to it having trailing arms. Even a torsion beam set up would do the same.
Posted: Sun Jan 03, 2021 7:52 pm |
Thanks, just seems strange.
Posted: Sun Jan 03, 2021 9:53 pm |
Edward wrote: |
It's down to it having trailing arms. Even a torsion beam set up would do the same. |
Probably what I meant .. I forgot what the torsion bars were called when typing the previous post!! Brain fade ...
