Latest: eniniex
Overall: 17113
Online Now [45]:
Visitors: 44
Today: 4602
Total: 93843582
Forums › The Car › 206 Problems › Rear rises on handbrake??
Batso
PostPosted: Sun Jan 03, 2021 6:51 am Up
I've noticed that, when I park on an incline (nose pointing uphill), and apply the handbrake, the rear of the car rises quite dramatically as I ease off the foot brake
Is this a rear axle bush problem?
Or is this car just haunted or something?
gazza82
PostPosted: Sun Jan 03, 2021 3:16 pm Up
Normal ... torsion bar rear suspension.
PostPosted: Sun Jan 03, 2021 5:08 pm Up
It's down to it having trailing arms. Even a torsion beam set up would do the same.
Batso
PostPosted: Sun Jan 03, 2021 7:52 pm Up
Thanks, just seems strange.
gazza82
PostPosted: Sun Jan 03, 2021 9:53 pm Up
Probably what I meant .. I forgot what the torsion bars were called when typing the previous post!! Brain fade ... Smile
