![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Need a new fuel tank, advise needed |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sat Nov 12, 2022 2:15 pm |
Hello all,
I've recently bought a 2001 206 GLX 2.0 HDI. Overall I like it but today while looking over it with my mechanic, we noticed that the fuel tank had a small leak from the top and the tank straps are pretty badly corroded. As we didn't remove the tank, as a backup, I need to source a new or used fuel tank and both tank straps.
If anyone knows them, could you please provide the relevant part numbers?
Also, are the 2 straps the same or are they different?
Many thanks
| | ![](images/spacer.gif) |
Posted: Mon Nov 14, 2022 9:28 am |
Only ever seen 1 fuel tank strap fitted on a 206 - they are a common failure, they where cheap new from Peugeot back in the day.
Both 206 I owned I had to replace the tank strap on.
| ![](themes/base/images/forums/otr.gif) |
