Latest: S2cgm
Overall: 17178
Online Now [71]:
Visitors: 69
Members: 1
Today: 69817
Total: 135879340
Forums › The Car › 206 Problems › central locking issue
marknico
PostPosted: Tue Oct 27, 2020 12:53 pm Up
Hi all after abit of advice - my 2004 206 5 door tries to lock itself everytime I open the drivers door only happens on inside handle any thoughts - it`s annoying as hell but weird as only does it exiting the vehicle from inside ???
jtq4u
PostPosted: Fri Apr 25, 2025 6:40 pm Up
adding my learning here about the central locking in case it helps anyone:
Just in case any one reads this thread at a later date, I seem to have discovered that there are two versions of the 206 drivers door lock - both with the same 6 pin connector!
One has a white plastic cover and a latch that comes up from the bottom onto the keeper and has a deadlock
The other has a black plastic cover and a latch that comes down from the top and has no deadlock
Bizzarely the pinouts are different and putting the black cased one onto a car expecting a white one causes the fuse to blow in the passenger compartment when you attempt to lock it with the remote.
Also it has the initial effect of locking the car as soon as you close the drivers door for the first time.
from my probing the black covered one which I had purchased from ebay I discover this is the wiring:
1 green -ve For door open (connects to pin 2)
2 green/yellow -ve
3 light brown lock motor
4 yellow -ve when dooe unlocked (connects to pin 2)
5 orange lock motor
6 pink -ve when door locked (connects to pin 2)
pins 3 and 5 can be experimented with using a 9v battery. one direction locks, the other direction unlocks.
There is no deadlock.
Then there is the white one on the car which is more of a mystry to me.
I can see that pins 1 and 2 still behave the same as before
WHAT I THINK BUT MAY NOT BE TRUE:
I think pins 3 and 5 may still do the motor too -
I think pin 6 may also be used to operate the deadlock - which explains why it blows the fuse when connected to a black unit that has shorted 6 to earth.
PostPosted: Sun Apr 27, 2025 8:34 am Up
There is also a switch contact inside the door lock motor that tells the car when the door is open or on the safety catch.
