Posted: Tue Feb 09, 2010 4:44 pm |
I posted this on the last site, so here we go again
I had the usual 206 rear worn axle problem, so after much deliberation I decided t buy a good second hand axle and refurbish it myself.
So the axle was 60 pounds and the bearings about 72 pounds. All finished it cost me about 130 pounds and about 6 hrs of time.
Note you will need access to hydraulic press to push torsion bars out of the arms and to assemble the bearings. But this could be done with a set of pullers and a decent vice.
The problem
Striped
second hand axle striped
new bearings
Posted: Tue Feb 09, 2010 4:46 pm |
images don't work
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Tue Feb 09, 2010 4:48 pm |
easy.......
they do now
Posted: Tue Feb 09, 2010 4:50 pm |
That makes taking the rear axle apart look easy, what tools did you use?
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Tue Feb 09, 2010 4:52 pm |
BIGGGGGG hammers and a load of brute force i bet!
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Tue Feb 09, 2010 5:02 pm |
nothing special usual stuff. However a press made life a lot easier
press looked something like this.
press
but I think you could do it with some pullers which look like this
pullers
Posted: Tue Feb 09, 2010 5:05 pm |
Oh right i see,
well its very useful thank you
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Tue Feb 09, 2010 5:10 pm |
Trade Rating: +31
The presses are around 140+ second hand on ebay Even still it's quite a technical process, not that simple! I'll be paying someone to do the 309's one that's for sure.
Posted: Tue Feb 09, 2010 5:12 pm |
| Brian wrote: |
The presses are around 140+ second hand on ebay Even still it's quite a technical process, not that simple! I'll be paying someone to do the 309's one that's for sure. |
But you learn from trial and error
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Thu May 05, 2011 12:55 pm |
3000+ views it must have been useful thread to start
Posted: Sat May 07, 2011 2:01 pm |
stupid questions, how did you press the outer oil seal in?
Posted: Sat May 07, 2011 2:04 pm |
They go in from either side
Tbh it aint a hard job, i did it with a sledge, a vice, small hammer, and chisel
It really is easy
| Team Impossible Possible
Posted: Sat May 07, 2011 2:09 pm |
| Addaz wrote: |
It really is easy |
because i end up with a busted rubber seal after i try to hammer it in
Posted: Mon May 09, 2011 2:59 pm |
| Seabook wrote: |
| Addaz wrote: |
It really is easy |
because i end up with a busted rubber seal after i try to hammer it in  |
Just taped them in with a hammer, make sure the surfaces are free from crud
Posted: Mon May 09, 2011 3:02 pm |
| vwaudi wrote: |
| Seabook wrote: |
| Addaz wrote: |
It really is easy |
Just taped them in with a hammer, make sure the surfaces are free from crud |
Bit of P80 wheel or a wire wheel would do
