Latest: eionpeu
Overall: 17120
Online Now [59]:
Visitors: 58
Today: 15753
Total: 97263843
Forums › The Car › 206 Talk › Goodridge Braided Brake Hoses - Group Buy
Go to page 1, 2, 3 ... 9, 10, 11  Next
PostPosted: Fri May 14, 2010 8:12 am Up
KamRacing wrote:
Kam Racing have offered Goodridge Braided brake hoses for
Goodridge hoses we can do the zinc plated kit for £42 + P&P and the stainless fitings for £50 + P&P. Postage would be £3 to UK addresses - if anyone wants it to go elsewhere let me know and I'll work out some shipping costs..
Payments would have to be via a direct bank transfer as some of the savings are from us not having to pay credit / debit card transaction fees..
If people wish to pay by Paypal I don't mind sorting out the bank transfer.
I've previously arranged 2 other successful group buys, I’m no scammer Smile
scr206
PostPosted: Fri May 14, 2010 8:16 am Up
ahhh what Sad got some of these last year! Paid £56 for them! well worth the money, so well worth jumping on the group buy if you can people
2001 2.0 HDi - Silver - SP grilles - Tinted Phase 2 rear lights - Re-mapped - Spax VSX - Group N gear linkages - GE Quickshift
2001 2.0 HDi - China Blue - SP Grilles - GTi leather interior
+4 buyer/seller feed back
PostPosted: Fri May 14, 2010 8:19 am Up
I know for sure Georgie will be intersted! Very Happy
Mrs_Howey
meady
PostPosted: Fri May 14, 2010 9:11 am Up
Trade Rating: +45
are these a diy fit or down a garage
TEAM - I HATE FACEBOOK Smile
|SGP|
PostPosted: Fri May 14, 2010 9:22 am Up
CD-206GTi wrote:
I'm able to get Goodridge Braided Brake hoses for £39.99 + P&P
does that mean the 39.99 includes the p&p, or 39.99 and then more for p&p? Laughing
Yay! Goodridge do orange Very Happy
sounds a bit iffy though.. found this on my google searching
some guy wrote:
They are not
recommended for street use. Reason: Lines are rigid and
will not flex with the body as it turns and reacts to
road imperfections--rubber hoses will. As a result, the
lines can often get pinched and fail. Stainless lines are
OK in racing applications because race cars are subject
to constant inspections/bleeding/maintenance. If there is
an alignment problem it will likely be discovered. Most
people probably are not as disciplined in street
applications making the this mod impractical. In
addition, most steel braided brake lines do not pass the
DOT tests and therefore technically illegal for street
use.
View my car
PostPosted: Fri May 14, 2010 9:24 am Up
P&P will be minimal, £1 - £2
PostPosted: Fri May 14, 2010 9:26 am Up
You can DIY if you know how to bleed your brakes as you'll need to replace the brake fluid.
I'll be taking mine to a garage for peice of mind, only will be ½'s labour or so.
PostPosted: Fri May 14, 2010 9:29 am Up
some guy wrote:
They are not
use.
Sounds like he's had a bad experience with some.
However these are braided, woven, which have plenty of flex, I can tell you this due to owning some a while back.
Rubber hoses expand when braking & degrade over time.
PostPosted: Fri May 14, 2010 9:35 am Up
If anybody is expecting to notice a difference with braided hoses ask yourself a question.
If rubber hoses gave spongey pedal feel would they fit them to pretty much every car? If they were that poor wouldn't the manufacturers spend an extra few quid and fit braided hoses?
Buy some braided hoses if you want some that look better but don't buy them if you think they will give better braking.
PostPosted: Fri May 14, 2010 9:37 am Up
Do you not have them on yours?
PostPosted: Fri May 14, 2010 9:41 am Up
I do have them and they make no difference at all. You'd have to be driving your car on track and using the brakes as hard as possible all the time to see any difference.
Also there's no point in getting stainless hoses with zinc coated fittings. You'll need stainless fittings too which cost extra.
PostPosted: Fri May 14, 2010 9:48 am Up
Thanks for the input, I'm judging interest on what would be a good upgrade. Its soley down to the buyers choice now.
Antix
PostPosted: Fri May 14, 2010 9:59 am Up
Custom - Red Stars
It's the fact that the Goodridge brake lines are thinner and don't expand (losing pressure) that are the 'plus points', surely?
The brake fluid is forced into the brakes quicker - therefore making the brakes more effective by being able to work sooner.
Before & after my brake hose replacement:
I have to say that it was a worthwhile purchase for my car.
PostPosted: Fri May 14, 2010 10:04 am Up
Nope, the walls of the rubber hose are thicker but interally they are the same.
Antix
PostPosted: Fri May 14, 2010 10:07 am Up
Custom - Red Stars
Nope, the walls of the rubber hose are thicker but internally they are the same.
The braided hoses look so much better than the rubber ones [and not likely to be cut by vandals/chavs/jealous rivals etc] Wink
Page 1 of 11
