Posted: Fri May 14, 2010 8:12 am |
Posted: Fri May 14, 2010 8:16 am |
ahhh what got some of these last year! Paid £56 for them! well worth the money, so well worth jumping on the group buy if you can people
| 2001 2.0 HDi - Silver - SP grilles - Tinted Phase 2 rear lights - Re-mapped - Spax VSX - Group N gear linkages - GE Quickshift
2001 2.0 HDi - China Blue - SP Grilles - GTi leather interior
+4 buyer/seller feed back | |
Posted: Fri May 14, 2010 8:19 am |
I know for sure Georgie will be intersted!
Mrs_Howey
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Fri May 14, 2010 9:11 am |
Trade Rating: +45
are these a diy fit or down a garage
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Fri May 14, 2010 9:22 am |
CD-206GTi wrote: |
I'm able to get Goodridge Braided Brake hoses for £39.99 + P&P |
does that mean the 39.99 includes the p&p, or 39.99 and then more for p&p?
Yay! Goodridge do orange
sounds a bit iffy though.. found this on my google searching
some guy wrote: |
They are not
recommended for street use. Reason: Lines are rigid and
will not flex with the body as it turns and reacts to
road imperfections--rubber hoses will. As a result, the
lines can often get pinched and fail. Stainless lines are
OK in racing applications because race cars are subject
to constant inspections/bleeding/maintenance. If there is
an alignment problem it will likely be discovered. Most
people probably are not as disciplined in street
applications making the this mod impractical. In
addition, most steel braided brake lines do not pass the
DOT tests and therefore technically illegal for street
use. |
Posted: Fri May 14, 2010 9:24 am |
|SGP| wrote: |
CD-206GTi wrote: |
Yay! Goodridge do orange |
P&P will be minimal, £1 - £2
Posted: Fri May 14, 2010 9:26 am |
meady wrote: |
are these a diy fit or down a garage |
You can DIY if you know how to bleed your brakes as you'll need to replace the brake fluid.
I'll be taking mine to a garage for peice of mind, only will be ½'s labour or so.
Posted: Fri May 14, 2010 9:29 am |
some guy wrote: |
They are not
use. |
Sounds like he's had a bad experience with some.
However these are braided, woven, which have plenty of flex, I can tell you this due to owning some a while back.
Rubber hoses expand when braking & degrade over time.
Posted: Fri May 14, 2010 9:35 am |
If anybody is expecting to notice a difference with braided hoses ask yourself a question.
If rubber hoses gave spongey pedal feel would they fit them to pretty much every car? If they were that poor wouldn't the manufacturers spend an extra few quid and fit braided hoses?
Buy some braided hoses if you want some that look better but don't buy them if you think they will give better braking.
Posted: Fri May 14, 2010 9:37 am |
Edward wrote: |
Buy some braided hoses if you want some that look better but don't buy them if you think they will give better braking. |
Do you not have them on yours?
Posted: Fri May 14, 2010 9:41 am |
I do have them and they make no difference at all. You'd have to be driving your car on track and using the brakes as hard as possible all the time to see any difference.
Also there's no point in getting stainless hoses with zinc coated fittings. You'll need stainless fittings too which cost extra.
Posted: Fri May 14, 2010 9:48 am |
Edward wrote: |
Also there's no point in getting stainless hoses with zinc coated fittings. You'll need stainless fittings too which cost extra. |
Thanks for the input, I'm judging interest on what would be a good upgrade. Its soley down to the buyers choice now.
Posted: Fri May 14, 2010 9:59 am |
It's the fact that the Goodridge brake lines are thinner and don't expand (losing pressure) that are the 'plus points', surely?
The brake fluid is forced into the brakes quicker - therefore making the brakes more effective by being able to work sooner.
Before & after my brake hose replacement:
I have to say that it was a worthwhile purchase for my car.
Posted: Fri May 14, 2010 10:04 am |
Antix wrote: |
Nope, the walls of the rubber hose are thicker but interally they are the same.
Posted: Fri May 14, 2010 10:07 am |
Edward wrote: |
Antix wrote: |
Nope, the walls of the rubber hose are thicker but internally they are the same. |
The braided hoses look so much better than the rubber ones [and not likely to be cut by vandals/chavs/jealous rivals etc]
