Latest: tbafonso
Overall: 17130
Online Now [239]:
Visitors: 238
Today: 68598
Total: 104258214
Forums › The Car › 206 Talk › Cruise control
Cruise control
Go to page Previous  1, 2, 3 ... 30, 31, 32 ... 34, 35, 36  Next
andrew96
PostPosted: Mon Apr 26, 2010 12:25 pm Up
wagsy206 wrote:
so, even though it says "invalid" and said download faulty, it still worked?
yes, but as it was just the instrument panel i think it just means that it is not showing any cruise control details, others here have said CC70 comes up where the milage apears if the CC control is on and set, but i dont get that, so presume the instrument panel setting is not to important as its the BSI and engine ECU that are important to be set
Cheers
Andrew
ExoVyper
PostPosted: Mon May 10, 2010 6:33 am Up
SAB206 wrote:
My CC stalk needs programming, just finding time to do it is a pain.
for those confused about the switch, it's the brown one on the clutch, (top of pic)
scott your a saviour putting that picture up!
my cars got the clutch switch and im pinching my dad's cc stalk off his 307 Very Happy Very Happy Very Happy
you are gonna get some bummage when i next see you scott Wink
ExoVyper
PostPosted: Mon May 10, 2010 10:34 am Up
SAB206 wrote:
I can get it installed for £36 Smile
where?
as two dealers near me won't touch it
i would drive Very Happy
wagsy206
PostPosted: Mon May 10, 2010 11:04 am Up
simon, do you have the 4 pin brake switch??
you need the brake switch and clutch switch or it wont work at all.
Wagsy206
old post count: 5000+
Team: Honda Accord
ExoVyper
PostPosted: Mon May 10, 2010 11:17 am Up
oh... :S
i have that brown switch on the clutch pedal
mattievrs
PostPosted: Mon May 10, 2010 11:20 am Up
there needs to be a break switch with 3 or 4 wires going into it (i think) behind the glovebox.
NO LONGER ACTIVE ON THE FORUM
wagsy206
check the passenger footwell where the braking system goes through the bulkhead, there MIGHT be a switch in there. and it'll either be 2x2 pin plugs or 1x4 pin plug.
this is why the vast majority of us have called a halt to it. i got quoted £240 to get everything, fitted and set up, IF it was a matter of just connecting and switching on.
Wagsy206
Team: Honda Accord
ExoVyper
PostPosted: Mon May 10, 2010 11:27 am Up
ah right...
thought it was too easy to plug the stalk in and program it xD
mattievrs
PostPosted: Mon May 10, 2010 11:31 am Up
other cars have them wired into the ecu, and although the 206 has the option via bsi im sure it would need some kind of splicing into the ecu but no one has mentioned this on here yet!
skard
PostPosted: Mon May 10, 2010 12:26 pm Up
i did, about a hundred pages ago! i saw it on a french 307 site when i first looked into this, hence why i sold the stalk. i'm not into hacking into ECU's!
mattievrs
PostPosted: Mon May 10, 2010 12:36 pm Up
Fair enough but it seems they still think its as easy as 1,2,3
ExoVyper
PostPosted: Mon May 10, 2010 1:41 pm Up
doh! i have the two wire plug Razz
oh well just means i dont have to bother taking my dads apart now Very Happy
Warrior
PostPosted: Fri Jun 25, 2010 11:16 am Up
Hi guys,
I'm a guy from Iran
I've fitted cruise control about 1 year ago! and i've enjoyed using it soooooooooooooooo much!!! It has helped me so much while driving Smile
I will be satisfied if i can help you installing it Smile
Also there's a problem!!!
I don't know what's happend but i opened a topic about installing my cruise control in this website about a year ago... but now i don't know where is it and also my username has been removed!!:O:O and i made it again!
Ok, back to our main lovely subject "cruise control".
I've to tell you that we've to kind of able to install the cruise control:
1-Those with the new TU3A engine
2-And those with the 1.6 TU5JP4 engine
Best regards,
Amir
Iran-Esfahan
206 1.6 Sedan - 2009 Model
Mitch
PostPosted: Fri Jun 25, 2010 11:49 am Up
Amir... the site crashed a few months ago. Make a new how-to... it will help users alot.
Warrior
PostPosted: Fri Jun 25, 2010 12:19 pm Up
Oh!!
How bad!!!
First: a correction:
I've to tell you that we've to kind of 206s able to enable the cruise control on:
About making a how to... topic i think i can't do it these days because i've taking my university exams and they'll be finished in about 10 days.
But now, and in this topic, i can guide you guys as much as i can till i make a new topic if you were interested.
First you guys tell me is there any one of you who has installed cruise control stalk & making it work?
And then tell me what's your problem?
Why can't you install the cruise control?(Sorry, i just had time to read about 2 pages of the topic)
Best regards
Page 31 of 36
