Online Now [1174]:
Visitors: 1173
Today: 42590
Total: 149120628
Forums › The Car › Solved 206 Problems › how to remove my spoiler
Forum Index › Solved 206 Problems
Go to page Previous  1, 2
PostPosted: Fri May 14, 2010 1:55 am Up
hectorbrocklebank wrote:
ok dude av got the wee plastic bits off but how do I now get to the bolts of the spoiler?If I cant see any bolts at this stage does that mean the spoiler is tiger sealed on?If so how do I know remove said spoiler? Very Happy
so you didn't find any hole under the plastic cover??,because there should be ahole,and when you look inside it,you will find the bolt,so if you don't have a hole,then your spoiler were tiger sealed on,and not a factory fitted one,it's hard to take it off without damage,so be careful,anyway you still need to take these off when you install your new spolier,and use bolts,it's much better. :),good luck
Page 2 of 2
