Latest: Worthy967
Overall: 17143
Online Now [251]:
Visitors: 250
Today: 15808
Total: 115790915
Forums › Tuning, Modification & Legal › Project Cars › Mattie® R3 Turbo /END
Go to page Previous  1, 2, 3 ... 16, 17, 18 ... 21, 22, 23  Next
PostPosted: Tue Jun 01, 2010 10:04 am Up
Jamie wrote:
There's nothing inherently wrong with Emerald, don't get me wrong, but they're using old software/technology compared to the newer systems. I'm not just saying that because I have the DTA, but I have the DTA because I did the research Wink
That's great but only if you are going to make use of those extra functions. At the end of the day if all you are using is 3 or 4 inputs to an ECU then any ECU regardless of cost will perform the same.
c2gt18
PostPosted: Tue Jun 01, 2010 10:06 am Up
what are the main functions of an ECU ?
ALL RED !
Mattie-RS
PostPosted: Tue Jun 01, 2010 10:07 am Up
mattie wrote:
do you have to time it up different if the compression has been lowered? Ie advance or retard the timing on the inlet and exhaust cams?
That my friend, i have no idea Laughing
Reason why i aint put timing belt on yet
Mattie-RS
PostPosted: Tue Jun 01, 2010 12:00 pm Up
c2gt18 wrote:
DO IT
www.maxpower.co.uk/art...02&p=3
Thats twin turbo and supercharged aint it?? and its only 1.4 8v aswell
With single turbo ill get more than 180, but depending on lag with mine i may eventually get twin charged Wink
nakednakeddave
PostPosted: Sat Jun 05, 2010 5:43 pm Up
c2gt18 wrote:
DO IT
that all????
looks disgusting anyway and has the back of a fridge for an intercooler....
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
Mattie-RS
PostPosted: Mon Jun 21, 2010 11:28 am Up
Purchased these from wozza at FCS so thought id have ago at putting them on,
Full front C4 VTS brake setup,
Calipers are the same as the 180, but apparently the discs are bigger (302 x 26mm)
Anyway much bigger than my stock setup, will let the pics do the talking.
So this was my old setup:
Old disc compared to new:
New setup:
New caliper:
The Discs only just fit, and i mean there's like a 5mm gap:
Tiny Old caliper with New bigger caliper:
Cool
Jamie
PostPosted: Mon Jun 21, 2010 11:43 am Up
Are the discs the right offset for a 206?
Mattie-RS
PostPosted: Mon Jun 21, 2010 2:27 pm Up
I'd have thought so
Everything went on perfect, lined up and fit right.
Jamie
PostPosted: Mon Jun 21, 2010 2:29 pm Up
Hmm dubious to try them with the Brembo's...
Mattie-RS
PostPosted: Mon Jun 21, 2010 2:40 pm Up
Tried looking for offsett the only difference i can find between the discs is the overall size
With the 180's im sure there will be a gap, with these its very tight they only just fit.
Jamie
PostPosted: Mon Jun 21, 2010 2:44 pm Up
I'd be tempted to get a set if the offsets are the same
SAB206
PostPosted: Mon Jun 21, 2010 2:47 pm Up
you got rear disks dude?
www.sab-graphics.com
I AM SYDLEXIC!
Mattie-RS
PostPosted: Mon Jun 21, 2010 2:49 pm Up
Would using both the C4 calipers and discs with a different offset to the 206 still fit tho??
not yet need carl to get a move on and sort me out with his
Jamie
PostPosted: Mon Jun 21, 2010 2:51 pm Up
No i meant get a set for the Brembos
Mattie-RS
PostPosted: Mon Jun 21, 2010 2:52 pm Up
Ah i see what size you got now with the Brembos??
Page 17 of 23
