Latest: Kifi69
Overall: 17183
Online Now [445]:
Visitors: 444
Today: 114735
Total: 144132572
Forums › Tuning, Modification & Legal › Project Cars › Jamie: GTi180
Jamie: GTi180
Go to page Previous  1, 2, 3 ... 32, 33, 34 ... 43, 44, 45  Next
Uz
PostPosted: Mon Jun 07, 2010 7:05 am Up
Oh the 4pot always squeel if they aren't running the 302mm disks. It's a known problem with them. You can try the shims that are available for them and see if they do anything...I know Misty do some on the Evo 4pots.
Jamie
PostPosted: Mon Jun 07, 2010 7:09 am Up
How do I get to run 302mm discs? What's involved?
What do the shims look like? Any links?
Uz
PostPosted: Mon Jun 07, 2010 7:17 am Up
I think you need to have a custom braket made to be able to run the 302 discs.
The shims look like the ones in the middle of the pic below;
4Pot Shims
But they will be for the 4pot calipers and slot-in inbetween the pad backing and the caliper pistons.
Seb
PostPosted: Mon Jun 07, 2010 7:26 am Up
Staff - Seb
Or you could just put some of the rubber damping pads on the back? Surprised
Jamie
PostPosted: Mon Jun 07, 2010 7:27 am Up
Does that stop the squeeling? What cures the increased pedal travel?
Jamie
PostPosted: Mon Jun 07, 2010 7:28 am Up
Also where would I buy the shims from?
Seb
PostPosted: Mon Jun 07, 2010 7:31 am Up
Staff - Seb
I did mine the other day - squealed like feck, rubber liners between the pad and piston damp the oscillations which create the noise.
With 4 pots - nothing, other than adding/changing a level I can imagine.
Jamie
PostPosted: Mon Jun 07, 2010 7:39 am Up
I can't seem to find any Sad
Jamie
Also what's a level?
Seb
PostPosted: Mon Jun 07, 2010 7:44 am Up
Staff - Seb
Lever*
!! If you change the ratio of the lever I can imagine it'll give a different feel, but I'm not sure how different that is on a 206 really... Surprised
Jamie
PostPosted: Mon Jun 07, 2010 7:48 am Up
I have no idea what that is!
Seb
PostPosted: Mon Jun 07, 2010 7:51 am Up
Staff - Seb
I can imagine the pedal runs off a lever that either increases or reduces the force you need to apply, but makes it easier. The longer the travel the easier it will be to push down and lock up, the shorter the travel for the same force on the lever, the more force your foot needs to put down, and the harder it will be to lock them fully up.
Legoless
PostPosted: Mon Jun 07, 2010 8:15 am Up
Jamie wrote:
Wheels fit with spacers, the brakes squeel like a pig.
Not impressed with them if I'm honest!
I think replacing the master cylinder would be smart. Mine squeal as well, but I think the most squeal comes from back pads and handbrake Smile
Regards,
Legoless
The LegoRC Project
Jamie
PostPosted: Mon Jun 07, 2010 9:15 am Up
What size discs are you using?
Legoless
PostPosted: Mon Jun 07, 2010 9:21 am Up
283mm stock size GTI180 size..
The LegoRC Project
Page 33 of 45
