Online Now [561]:
Visitors: 560
Today: 138584
Total: 145444265
Forums › The Car › 206 Talk › [Body Repair] Spray Marks?
Forum Index › 206 Talk
myke
PostPosted: Mon Jul 26, 2010 10:08 am Up
Hi guys, just resprayed my bits for under the headlights (which may I add came out rather fine for a first attempt at spraying anything - thanks for the hints Teebag), but without realising I got to the end of the can and it sprayed out some larger, darker bits of paint which can be seen in this picture:
Is there a way to get rid of them? can I polish them out?
arronmee1990
PostPosted: Mon Jul 26, 2010 10:29 am Up
Maybe try claying it. That will remove over spray but I don't know about big clumps of paint Smile
My Project Thread
Schnakey
PostPosted: Mon Jul 26, 2010 5:10 pm Up
Polish it. If it's the very top layer it will polish off.
copey
PostPosted: Tue Jul 27, 2010 1:24 am Up
could you sand it with some fine wet and dry, then machine polish it out?
02 2.0 hdi d turbo
LilLew
PostPosted: Tue Jul 27, 2010 1:31 am Up
Mix up a washing bowl of water and the good old fairy liquid and get some 2000 grit sand paper and some 2500grit or higher (MUST BE WET & DRY) dunk the sand paper in the water then lightly rub the paint until smooth then re clear coat it and polish
2003 Pug 206 2.0 GTI 180
myke
PostPosted: Tue Jul 27, 2010 3:24 am Up
Thanks everyone - Teebag helped me do it yesterday, looks much better now Very Happy thanks!
