Latest: tebas93089
Overall: 17179
Online Now [105]:
Visitors: 104
Today: 87023
Total: 138051962
Forums › The Car › 206 Talk › Hdi overheating
Hdi overheating
eddrj
PostPosted: Wed Aug 04, 2010 1:51 am Up
Noticed that temp rises to 90 or almost 100 has never been rite at top by red but still surely shoudnt always be on 90 or 100ish ??? in traffic or waiting isnt as high when driving around though any ideas
Old car 2000/ 206 2.0 hdi.
Locky
PostPosted: Wed Aug 04, 2010 2:02 am Up
Sounds about right to me.
2001 HDi D-Turbo, China Blue, Multiplexed.
eddrj
PostPosted: Wed Aug 04, 2010 2:04 am Up
o ok is it really has been on 100 before think thats normal ? always think its guna reach top but never gets there not sure if the fan is working
n1ck106
PostPosted: Wed Aug 04, 2010 2:31 am Up
mine sits about 82. 90-92 when in traffic and when giving it some pedal
im niki Very Happy
Locky
PostPosted: Wed Aug 04, 2010 2:57 am Up
The fan should be kicking in just after it goes past the 90 or so (give or take) - but its a common fault for the fan to stop working, probably due to water getting into the housing where the relays are. You have air con? If so, put it on and see if the cooler fan starts up after running for a while. Its the same cooler fan that cools the engine and the gas in the condenser.
If the fan isnt spinning up after the air con has been running for a while, or the engine temp is nearing 100 then you need to investigate further. My money would be on corrosion of the relays.
ExoVyper
PostPosted: Wed Aug 04, 2010 3:34 am Up
i talked to the stealers about this when i had my 206 and they said that the hdi 206's fan doesn't kick in till about 105 degrees :S
Quarmbo
PostPosted: Wed Aug 04, 2010 4:05 am Up
Gets hotter driving around then when at a stand still? Shouldn't it be the other way round?
Ford SportGay-A
eddrj
PostPosted: Wed Aug 04, 2010 4:14 am Up
i have air con but it doesnt work ran out of gas ok so sounds normal then so doesnt fan kick in till 105 no wonder ive never seen or heard it on lol
Locky
PostPosted: Wed Aug 04, 2010 4:33 am Up
The air con wont work if the cooler fan doesnt work either mate. You know for sure it just needs a recharge?
To check this you will need someone else to help, but can you hear the relay click when putting on the A/C?
If it does click, possibly you just need an air con recharge - if it doesnt click, then you need to inspect the relays.
eddrj
PostPosted: Wed Aug 04, 2010 4:41 am Up
ok didnt know that cheers no not 100% sure if does work or just needs a charge alrit cheers for help mate
