Latest: sparrowdclxvi
Overall: 17139
Online Now [73]:
Visitors: 72
Today: 20591
Total: 112533236
Forums › The Car › 206 Talk › Doing the torsion bar tomorrow...any advice?
l1nuxxx
PostPosted: Wed Aug 04, 2010 6:51 am Up
Going to have a go at lowering the rear tomorrow, I have sprayed penetrating oil on the torx screws and the surrounding area today so hopefully this will help in removal, I have had a look at the how to and it says there are 2 torx screws per side to remove but I can only see one? Any advice as to where the second one is and any advice on the job at all would be great.
Andy
206 1.4 GLX
PostPosted: Wed Aug 04, 2010 7:19 am Up
Look a bit harder and you will find them! If you're at the still at the stage of looking for the torx screws you aren't ready for doing the torsion bars yourself! Yet.
l1nuxxx
PostPosted: Wed Aug 04, 2010 7:29 am Up
I havent even taken the wheels off yet it was just so I could get in with the penetrating oil to let them soak, I lowered the rear torsion bar on my old clio and it was a piece of cake so I have been told this is easier to do. I will take the wheels off and have a look.
206 1.4 GLX
Ruffy_206
PostPosted: Wed Aug 04, 2010 7:31 am Up
Custom - Gold Stars
the torx are at the end of each bar. you must not be looking at the other bar then? and if i was you id get some new torxs to go back in along with the pear washers
PostPosted: Wed Aug 04, 2010 7:34 am Up
Yes buying new bolts is well worth it. There's a good chance you'll round the old ones off a bit so for what small amount they cost they're worth buying. Get some copper grease for the new ones too.
l1nuxxx
PostPosted: Wed Aug 04, 2010 8:03 am Up
Cheers for the replys guys, I have found the 2 torx now, does anyone have the part number for the torx screws and washers from peugeot?
Andrew
206 1.4 GLX
Ruffy_206
PostPosted: Wed Aug 04, 2010 8:20 am Up
Custom - Gold Stars
5153 20 torxsx4
5153 19 washers x4
comes to about £10 all together
D4NTP
PostPosted: Wed Aug 04, 2010 8:42 am Up
Only my opinion but if you rely on the car daily i'd make sure i had acces to some easyouts as well. and maybe some burning gear just incase things get really stuck and you need some heat.
l1nuxxx
PostPosted: Wed Aug 04, 2010 9:03 am Up
Yeah I was thinking that mate, I am off this week so I have a few days to sort it if anything goes wrong. Do you think a decient blow torch would suffice?
206 1.4 GLX
PostPosted: Wed Aug 04, 2010 10:49 am Up
Park near a wall too and put a block of timber between the trailing arm and wall, otherwise when you hit the torsion bar you'll probably end up knocking the arm off the axle tube.
Squeaker
PostPosted: Wed Aug 04, 2010 10:57 am Up
Get a huge hammer and a big can od WD40, when i did mine, it was in solid. i was whacking, spraying, whacking, spraying, with the odd hitting of my hand with a metal mallet, kind of hurts Smile
Ive got to raise the rear end on mine, but i absolutly lathered it all in copper grease, so it "should" knock straight out this time.
LilLew
PostPosted: Thu Aug 05, 2010 2:47 am Up
Lol I love the should
2003 Pug 206 2.0 GTI 180
