Online Now [512]:
Visitors: 511
Today: 112466
Total: 105440854
Forums › The Car › 206 Talk › Wiper Blades...
Wiper Blades...
myke
PostPosted: Thu Aug 05, 2010 4:37 pm Up
Ok ... total noob here..
First time buying wiper blades, few questions.
I have a 52 plate 206.
1) What are aero blades? Are they much better?
2) Are aero blades easy to fit?
3) Prices? Recommendations?
4) Will these fit:
cgi.ebay.co.uk/PEUGUOT...497wt_1026
5) What size am I looking at for my 206, front and rear?
Sorry for so many questions - this is my first time buying Embarassed ... it was the 'tesco' thread that made me aware of aero wipers...
206-GTi
PostPosted: Fri Aug 06, 2010 1:37 am Up
Aero are nice! Dont buy them cheap ones, Buy cheap buy twice.
Bosch do really good ones example here
They are the same to fit as normal wipers. Not sure what your sizes are, but my car is 02 and the wipers are 22/22 on the front. The rear wiper is the same on every car.
Check out www.wiperblades.co.uk and go through the car checks and it will present you with what you need at the end.
GTi - Black - 2002
myke
PostPosted: Fri Aug 06, 2010 1:41 am Up
Cheers 206 - they're a bit more than I thought they'd be when I saw all the cheap prices on ebay haha Razz
I'll wait until my car's back from the body shop and have a look then.
Cheers again Very Happy
Them ones on wiperblades.co.uk are only 6.20 each... that sounds a good price? They're also recommended by Auto Express which I read regularly so I might get them Surprised ...
Danw_VVT
PostPosted: Fri Aug 06, 2010 1:56 am Up
aero blades from tesco are about £6 each and work brilliantly use search bar and search tesco wiper blades and have a look.
myke
PostPosted: Fri Aug 06, 2010 2:25 am Up
Oh, cheers Dan - will have a look now.
Danw_VVT
PostPosted: Fri Aug 06, 2010 2:26 am Up
no probs!
bertt
PostPosted: Fri Aug 06, 2010 2:50 am Up
may get meself a set of them. . .
myke
PostPosted: Fri Aug 06, 2010 1:00 pm Up
I just ordered a set - once my car gets back from the body shop, I'll put them on and let you know how I get on.
PostPosted: Fri Aug 06, 2010 1:45 pm Up
Aeroblades don't wipe any better than normal window wipers, they just look better.
Also with aeroblades you need a inch shorter, so its 21/21
myke
PostPosted: Fri Aug 06, 2010 2:58 pm Up
Dam. Wiperblades.co.uk told me I need two 22" so that's what I bought.
I'll see what happens and return them if they don't fit, thanks for the heads up Lee Embarassed
silvertwo-oh-six
PostPosted: Sat Feb 01, 2014 7:10 am Up
Ordered a set of 22" aero wipers.
Ad even stated "peugeot 206".
Wiper on o/s hits the window trim on the side nearly bending the wiper?
Is it the wiper being too big? The seller being a retard and not giving right size (states 22" on the box), or aero wipers need to come in smaller size to fit?
MrRichmond1995
PostPosted: Sat Feb 01, 2014 7:18 am Up
I have the same problem with the o/s hitting the window trim
What I did to cure it was slightly file down the end of the wiper blade.
Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Sat Feb 01, 2014 7:30 am Up
Although 22" is correct for OEM, it has been found that the 21" aero fits perfectly. Some compatibility lists will state that 22" is needed which makes it really confusing.
silvertwo-oh-six
PostPosted: Sat Feb 01, 2014 8:10 am Up
Thanks guys. May contact the seller to see if he will swap.
Is it suggested 21 for both sides? Or just o/s
PostPosted: Sat Feb 01, 2014 8:21 am Up
I got a 21s on both sides. Not had a problem with them
