Latest: tbafonso
Overall: 17130
Online Now [291]:
Visitors: 290
Today: 11577
Total: 104647910
Forums › Tuning, Modification & Legal › Project Cars › The Timeattack 206 Gti Turbo: Lancer Evo radiator fitted!!
Go to page Previous  1, 2, 3 ... 8, 9, 10 ... 14, 15, 16  Next
White_Noise
PostPosted: Sun Aug 08, 2010 4:42 pm Up
Nothing on my car is without purpose! The support rods provide extra stability to the spoiler otherwise the spoiler would wobble to much.
Powered by:
mattymj
PostPosted: Sun Aug 08, 2010 5:03 pm Up
Just read from page 1 to here.
Excellent. I enjoy reading threads like this.
Keep up the good work.
EdCherry
PostPosted: Sun Aug 08, 2010 5:23 pm Up
If those support rods are serving a purpose and taking load then I hope you've got shares in whoever makes them.
They are meant to be used in tension not compression. They will not add stability under compression so you will be likely to find they will bend or just wobble about.
White_Noise
PostPosted: Sun Aug 08, 2010 6:38 pm Up
I've made these my self and are an exact replica of the ones J's Racing makens. They are made of 10mm massiv aluminium rod with threads on each side with balljoints on each side.
Powered by:
MEGA
PostPosted: Mon Aug 09, 2010 8:50 am Up
why are there 8 random holes on the back bumper? Looks dodgy...
Interesting project though!
The Collection:
2009 E90 BMW 320d M-Sport: Remapped / ICE install / BBC CH Alloys etc
2004 Pug 206: The BEAST / Raaawr
Danw_VVT
PostPosted: Mon Aug 09, 2010 9:31 am Up
this is why the bumper has holes!
"Also fitted a Golden Eagle diffuser this weekend! This diffuser is common on a lot of Japanese drag and trackcars. It lowers drag of the rearbumper, because the wind can now escape through the holes in the diffuser and bumper. It still has to be spray painted matt black for finishing touch. "
mattymj
PostPosted: Mon Aug 09, 2010 12:12 pm Up
This is the problem when people don't read from the start!!
PostPosted: Mon Aug 09, 2010 12:13 pm Up
Would be brilliant if the bodywork looked standard...the way the front calipers sit angled down remind me of those on some Seats...
MEGA
PostPosted: Tue Aug 10, 2010 1:55 am Up
OK but has the random hole in the bumper theory been proved? 1/4 mile best of 3 both before and after the mod?
IMHO it won't make a blind bit of difference. The rest of the car is not aerodynamic enough for the diffuser to be a significant gain/loss of time.
I am playing devils advocate here; But if you CAN prove that the mod has a significant affect on downforce in a peugeot 206 then I would be very interested in that Smile
The Collection:
White_Noise
PostPosted: Tue Aug 10, 2010 5:28 am Up
The shape of this specific model rearbumper acts like one big parachute, because it's lower than the original 206 bumper. The holes only let the air underneath the car escape easier. If you would have read the complete topic you would have noticed the bottom of the car will be closed after the exhaust has been installed, simulair to the picture below.
However it's not possible to to completly make the bottom airtight and that's why the holes are in the car. It might not been proved on a 206, beacause it's never been done as far as i know i'm the first one that is experimenting with it. Anyhow there have been enough test on other cars on wich it had good results, so we will see.
Powered by:
White_Noise
PostPosted: Tue Aug 10, 2010 12:48 pm Up
EdCherry wrote:
Whats with the rear spoiler support rods, not exactly going to do much are they?
I now see why you brought this up, i only had pictures of the old desing on in this topic, i forgot to post the pictures of the new design . This is the final design of the spoilerrods, 10mm thick aluminum rods with m6 threads at each end with stainles steel balljoints on them.
Powered by:
=ZiAn=
PostPosted: Mon Aug 16, 2010 6:37 am Up
I love this car. If I had the money I'd go down exactly the same route. But for now I'm keeping it a bit more simple than you Smile
ZianDesigns - Website designs
White_Noise
PostPosted: Mon Aug 16, 2010 7:11 am Up
Well honestly if i had the money again i would bougt an Evo Razz
Powered by:
=ZiAn=
PostPosted: Mon Aug 16, 2010 7:26 am Up
lol, you've got a point there =)
White_Noise
PostPosted: Mon Aug 16, 2010 7:28 am Up
It's fun to own this car dough, but i spent almost 30k on this car, for that kind of money i could buy an awesome evo Razz Instead of that i have a awesome pug! Razz
Powered by:
Page 9 of 16
