Latest: tebas93089
Overall: 17179
Online Now [72]:
Visitors: 72
Today: 43488
Total: 138517003
Forums › The Car › 206 Talk › Best place to Jack up the pug
Lowercase
PostPosted: Thu Aug 12, 2010 7:32 am Up
Fitting my new susspension this weekend, got all the kit i need finaly, and a mate.
wheres the best place to jack up the front and back with a trolley jack so i can get the axel stands under the sill jacking points. ?
Iain
PostPosted: Thu Aug 12, 2010 7:34 am Up
I jack it up using the points that you want to put axle stands under.
Our snow > Your snow
PostPosted: Thu Aug 12, 2010 7:36 am Up
Without much knowledge I do the rear on the part next to the shocks (attached too the frame) and on the fron't on a small plate just inwards of each of the springs. Never had a problem with them.
richpowell91
PostPosted: Thu Aug 12, 2010 7:40 am Up
I always try to jack it up under any strong part of the chasis and then put the axle stands under the subframe close to where the wishbones are mounted, as ive found the sill jacking points are a bit flimsy. Not sure where to jack it up under for the rear though so would also be interested in where people do.
PostPosted: Thu Aug 12, 2010 8:30 am Up
Click
Lowercase
PostPosted: Thu Aug 12, 2010 12:41 pm Up
cheers.
Locky
PostPosted: Thu Aug 12, 2010 12:50 pm Up
Hate the fact my trolly jack doesnt fit under the car until I lift it a bit with the stock jack - and i dont even consider my car particularly low. Maybe my jack is just masseeeve.
2001 HDi D-Turbo, China Blue, Multiplexed.
tyrone81
PostPosted: Fri Aug 13, 2010 11:12 pm Up
I go under the front bumper of the car and jack up on the subframe. with this
www.machinemart.co.uk/...olley-jack
Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
PostPosted: Sat Aug 14, 2010 1:16 am Up
I used to drive up on a block of wood befor I could get the jack under. Laughing
DeadEyePaul
PostPosted: Sat Aug 14, 2010 5:53 am Up
i'm having this problem as well Laughing so thats a good tip Cool
PostPosted: Sat Aug 14, 2010 5:57 am Up
Failing the wood, an Argos catalogue works spot on as well! Wink
Ali_H
PostPosted: Sat Aug 14, 2010 6:03 am Up
Same with my 306 Laughing
kurtis wrote:
DeadEyePaul
PostPosted: Sat Aug 14, 2010 6:13 am Up
[quote="tomd0801754"]
wahoo thanks again Cool
Locky
PostPosted: Sat Aug 14, 2010 7:31 am Up
Oo nice ideas. Suppose a brick would do the trick too.
PostPosted: Sat Aug 14, 2010 2:07 pm Up
Yep decently does Wink
:). Done that once ir twice too
