Latest: Beduff1977
Overall: 17134
Online Now [168]:
Visitors: 167
Today: 67099
Total: 108590278
Forums › The Car › 206 Talk › Oil Cooler
Oil Cooler
Go to page Previous  1, 2
Lodey
PostPosted: Tue Aug 17, 2010 7:32 am Up
You may have to share some info on where to buy parts Wink there's a guy on cupra.net with it mounted behind there, with it just viable behind the slat below the badge grill on the R bumper, looks smart as hell
Team: 20vT power
Ape
PostPosted: Tue Aug 17, 2010 7:45 am Up
Aye, that's where the idea came from. It will hide the engraved Forge FMIC as well Laughing
On a 206 however, anywhere in the front grille will be adequate I'd imagine
Lodey
PostPosted: Tue Aug 17, 2010 7:48 am Up
on a 206 i would be tempted to put it behind the upper grilles, would look cool i would think Smile
Need to find a Twin pass intercooler for mine, Smile
Team: 20vT power
twed207
PostPosted: Tue Aug 17, 2010 8:04 am Up
seat sport one? Smile
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
PostPosted: Tue Aug 17, 2010 10:19 am Up
Ape wrote:
Anything you do to keep engine temperatures to a minimum is worth doing in my eyes.
That's suggesting get rid of as much heat as possible. Overcooling the oil is very undesirable.
But you wouldn't be able to see it....
Ape
PostPosted: Tue Aug 17, 2010 10:44 am Up
Thats why you use a sandwich plate with a thermostat in it (as mentioned) to prevent over cooling.
LeeMaddern
PostPosted: Tue Nov 22, 2011 6:49 am Up
Has anybody fitted one to there 180 yet ?
More photos on FaceBook - www.facebook.com/lmaddern1
PostPosted: Tue Nov 22, 2011 11:49 am Up
You kind of have one on the 180 already.
PostPosted: Tue Nov 22, 2011 1:18 pm Up
Im fitting one for the conversion for my 1.4, pretty p**s easy tbh
You just need to calculate the flow of oil from the pump (check the pump is within tolerences and pushing out what it should) and this should allow you to find which one will be suitable for your needs.
To large and the pump cant cope = starvation. To small = Oil burns/thins
D4NTP
PostPosted: Tue Nov 22, 2011 2:29 pm Up
Considered fitting one but it never gets near the red and i use 10w60 millers race oil so the high temp wont thin the oil that much anyway. I'd go for better oil rather than a cooler.
Page 2 of 2
