Online Now [1166]:
Visitors: 1166
Today: 131035
Total: 146585949
Project sleeper
Go to page Previous  1, 2, 3 ... 35, 36, 37 ... 85, 86, 87  Next
spike_202
PostPosted: Sun Aug 08, 2010 2:07 am Up
did you have to pay for the loom your self paul?
**spike's project**
TEAM:+200bhp
PostPosted: Sun Aug 08, 2010 4:27 am Up
No. All delivered to me free of charge. It's about £80 worth retail. Will cost me between £200 - £300 to get it all connected plus about £70 worth of other bits such as relays, switches, Junior Power Timer connectors (for the injectors and coolant temp sensor) and braided sleeving etc.
There is quite a long list of components needed to build up a loom.
JoN-
PostPosted: Sun Aug 08, 2010 9:39 am Up
Karma
Jamie
PostPosted: Sun Aug 08, 2010 10:37 am Up
Karma?
spike_202
PostPosted: Sun Aug 08, 2010 11:01 am Up
glad i didnt take it to them now 2bf as they were on my list of garages when i had mine done, any way glad to hear your getin it sorted now mate.
**spike's project**
TEAM:+200bhp
White_Noise
PostPosted: Mon Aug 09, 2010 2:55 pm Up
Nice car! Totally different then mine dough, but i love it!!
Where did you got the Peugeot Sport GP A wishbones? I can't buy them here in the Netherlands..
Powered by:
PostPosted: Mon Aug 09, 2010 2:57 pm Up
Got them from Peugeot Sport in France...
Schumi
PostPosted: Mon Aug 09, 2010 3:37 pm Up
If you want a good job. You must do yourself.
I'm glad to help you about wiring loom or standalone ecu without stock ecu.
2005 206 RC RED
PostPosted: Wed Aug 18, 2010 11:55 am Up
Things are about to start moving with this. Next week the car is getting rewired so the Omex can run truly standalone.
Just bought a lambda sensor boss plug too. £8 delivered for a stainless steel item! Bargain. Not. The downstream lambda sensor is still in place but isn't being used to control the engine in any way. So I might as well remove the lambda sensor and the wiring for it can also go too. I'm also going to remove the EGR valve and its wiring, only problem is the blanking plate and gasket with bolts cost £31 from the Peugeot dealer. It's a standard part from a GTi 180 too.
macj
PostPosted: Wed Aug 18, 2010 12:12 pm Up
A man of your calibre should be able to make one. I used a bit of 3mm steel plate and used the old gasket as a pattern.
Ape
PostPosted: Wed Aug 18, 2010 2:26 pm Up
I've got a lambda boss you could've had if you'd have said. I'm using my second sensor to prevent fault codes so the boss is sitting in a bits box now! Ah well
PostPosted: Wed Aug 18, 2010 2:43 pm Up
I've already got a boss fitted. I just needed a plug to fill it.
As for the EGR plate I did think about making my own but sometimes it's just easier to put my hand in my pocket!
Ape
PostPosted: Wed Aug 18, 2010 2:59 pm Up
Sorry bud, I meant the plug, it's been a long day
macj
PostPosted: Wed Aug 18, 2010 3:18 pm Up
How much you want for it Ape
Ape
PostPosted: Wed Aug 18, 2010 3:32 pm Up
Will let you know after this weekend bud. Getting the LCR remapped this weekend to marry all the modifications together so if we map the second sensor out I'll need it. Slim chance mind though so I'll let you know, I'm sure Blueflame would supply if asked thinking about it Smile
Page 36 of 87
