Posted: Fri Aug 20, 2010 9:22 am |
Hi, does anyone know the correct pressure for Nimrod's fitted with Toyo 195/45/16 's ?
Cheers
Posted: Fri Aug 20, 2010 9:29 am |
Not sure what they are exactly supposed to be but i put 34 in the front and 32 in the back, i think i read this somewhere else.
Posted: Fri Aug 20, 2010 9:38 am |
it tells you on the big selvery sticker on the B pillar of the drivers door.
Posted: Fri Aug 20, 2010 9:39 am |
32PSI all round, unless carrying weight then its 32front and 36 at the back.
Posted: Fri Aug 20, 2010 9:40 am |
It only tells me my standard wheel pressure on the b pillar, its a 1.4 glx with nimrod's on, standard is steelies for that model
Read the text on the tyre, it will also say on there
| Now sold:Pug 206 1.4 Quiksilver 3dr
New car: Grande punto 1.9m-jet sporting
Team: the SillyHilly fan club
Was: monkeyboy69s Now: C-MAN | |
Posted: Fri Aug 20, 2010 9:42 am |
32 sounds to be what everyone is saying, I put in 30 last week so not far off
Posted: Fri Aug 20, 2010 9:43 am |
it only says max inflation on the tyre. each car will be a different weight so will need different pressures....
Posted: Fri Aug 20, 2010 9:46 am |
Quote:: |
Read the text on the tyre, it will also say on there |
It says the max pressure on there but not the recommended pressure
Posted: Fri Aug 20, 2010 9:47 am |
fair do, i must be lucky then that what it says on the tyre is the recommended for my car then
You do normally put more in the from to compensate for the weight of the engine etc.
