Online Now [160]:
Visitors: 159
Today: 1050
Total: 138736472
Forums › The Car › 206 Talk › Correct pressure for Tyres
crea2k
PostPosted: Fri Aug 20, 2010 9:22 am Up
Hi, does anyone know the correct pressure for Nimrod's fitted with Toyo 195/45/16 's ?
Cheers Cool
kev_flint
PostPosted: Fri Aug 20, 2010 9:29 am Up
Not sure what they are exactly supposed to be but i put 34 in the front and 32 in the back, i think i read this somewhere else.
twed207
PostPosted: Fri Aug 20, 2010 9:38 am Up
it tells you on the big selvery sticker on the B pillar of the drivers door. Smile
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
PostPosted: Fri Aug 20, 2010 9:39 am Up
32PSI all round, unless carrying weight then its 32front and 36 at the back. Smile
crea2k
PostPosted: Fri Aug 20, 2010 9:40 am Up
It only tells me my standard wheel pressure on the b pillar, its a 1.4 glx with nimrod's on, standard is steelies for that model
C-MAN
Read the text on the tyre, it will also say on there
Now sold:Pug 206 1.4 Quiksilver 3dr
New car: Grande punto 1.9m-jet sporting
Team: the SillyHilly fan club
Was: monkeyboy69s Now: C-MAN
crea2k
PostPosted: Fri Aug 20, 2010 9:42 am Up
32 sounds to be what everyone is saying, I put in 30 last week so not far off Smile
twed207
PostPosted: Fri Aug 20, 2010 9:43 am Up
it only says max inflation on the tyre. each car will be a different weight so will need different pressures....
206 2.0HDi
My 207 WIP
L200 thread
crea2k
PostPosted: Fri Aug 20, 2010 9:46 am Up
It says the max pressure on there but not the recommended pressure
C-MAN
PostPosted: Fri Aug 20, 2010 9:47 am Up
fair do, i must be lucky then that what it says on the tyre is the recommended for my car then
kev_flint
You do normally put more in the from to compensate for the weight of the engine etc.
