Latest: cogeim7
Overall: 17185
Online Now [483]:
Visitors: 482
Today: 7780
Total: 147744945
Forums › The Car › 206 Talk › epic mot fail
epic mot fail
Forum Index › 206 Talk
andyeuro206
PostPosted: Fri Aug 20, 2010 10:01 am Up
and here is the list lol
*nearside headlamp too low
*offside headlamp too low
* centre rear statutory seat belt missing (due to garros rear seats)
*nearside front constant velocity joint gaiter insecure
* offside front conctant velocity joint gaiter insecure
*nearside frount lower suspension arm has excessive play in ball joint
*nearside (front to rear) brakepipe inadequately clipped
*exhaust emissions carbon monoxide content at idel excessive
*exhaust emissions carbon monoxide content after 2nd fast idel excessive
*exhaust emissions hydrocarbon content after 2nd fast idel excessive
* service brake efficiency below requirements
where is the cheepest place you guys have found to by exhausts standerd ones at the just had the dreaded mot and i got a list a big list
PostPosted: Fri Aug 20, 2010 10:09 am Up
Second hand or brand new?
Second hand scrappy, here, ebay maybe.
Or brand new ebay as well or www.eurocarparts.com cheaper than pug
PostPosted: Fri Aug 20, 2010 10:15 am Up
Google
andyeuro206
PostPosted: Fri Aug 20, 2010 10:19 am Up
Wow that's going to be expensive Sad
sillyhilly
PostPosted: Fri Aug 20, 2010 10:25 am Up
No its not.. thats probably one of the cheapest 'epic fails' ive ever seen Confused
Hi Mikey Smile
andyeuro206
PostPosted: Fri Aug 20, 2010 10:27 am Up
i know its not got going to be expenxive i am on about the sheer amount of stuff needed sorted
PostPosted: Fri Aug 20, 2010 10:32 am Up
Way I looked at it was:
New driveshafts, £180 + fitting.
New wishbone £80 + fitting
New exhaust & sensors £200
Headlamps can be adjusted for free
Seatbelt, if you already have it can be bolted on free.
Brake fluid replaced & bled £60
New brake line £15~
Geoff
PostPosted: Fri Aug 20, 2010 11:00 am Up
New brake line £15~
You could probably get away with just a gaiter kit which will be around £100 fitted for both sides. Brake lines will be more than £15.
Its not too bad, just looks bad.
My last car required £1600 in parts for its MOT, it was swiftly auctioned Rolling Eyes
PostPosted: Fri Aug 20, 2010 11:09 am Up
Is it just loose gators or broken gators?
sniper1
PostPosted: Fri Aug 20, 2010 5:19 pm Up
ooooooo good job lol
but on a serious note i wouldnt worry too much, just sounds alot....had any quotes for the work to be done ??
