Latest: jackrox1992
Overall: 17186
Online Now [450]:
Visitors: 449
Today: 3486
Total: 148545286
Forums › The Car › 206 Talk › 180 delay
180 delay
Forum Index › 206 Talk
jamiea69
PostPosted: Sat Aug 21, 2010 3:14 am Up
i just wonderd whether this happens to anyone else. when i try to pull away quickly there is a slight delay b4 the power kicks in. like a flat spot.
225 cupra r
PostPosted: Sat Aug 21, 2010 3:51 am Up
That's where the missing 10-20 bhp should be, lol.
LilLew
PostPosted: Sat Aug 21, 2010 3:57 am Up
i have it on mine but then i notice it is the ESP kicking in and cuting power to stop the wheels spinning
if your is not swpinning then i would get a remap to sort the delay out
2003 Pug 206 2.0 GTI 180
jamiea69
PostPosted: Sat Aug 21, 2010 4:08 am Up
i thought it was the lack of torque?
225 cupra r
Drake
PostPosted: Sat Aug 21, 2010 4:25 am Up
lack of torque would mean it pulls pathetically, not cause a delay.
I used to have the same problem but it reduced when I changed the crappy air filter for a K&N panel filter.
54' 206 GTi 180 Silver - K&N panel filter, Scorpion cat back exhaust, Parada Spec 2s
gti180boy
PostPosted: Sat Aug 21, 2010 6:28 am Up
for some strange reason the gti180 between 3000rpm to 4000rpm all have a flat spot on them. if you have in on a dyno you will see it on a grath.
a remap can smooth it out but you can never really get rid of it.
180 Doctor
jamiea69
PostPosted: Sat Aug 21, 2010 7:20 am Up
really, i havent noticed that. just seems to be when i pull away
225 cupra r
Ash
PostPosted: Sat Aug 21, 2010 7:29 am Up
When was it last serviced?
sniper1
PostPosted: Sat Aug 21, 2010 7:51 am Up
yea i have it on mine dude....i am hoping the induction kit i am getting will sort it out but we will see
jamiea69
PostPosted: Sat Aug 21, 2010 4:47 pm Up
june, it was serviced. every thing is new. even had cambelt change
225 cupra r
